RS-232 with 16F877
MikeyG79
Starting out a new project and just trying to write some bits for my computer to read (just using cat /dev/ttyS1)- here is part of what I have so far, not sure why it doesn't work
Main:
call Print_Message
movlw 90H
movf TXREG
call Delay1sec
goto Main
Print_Message:
call LCD_Init
call Delay10ms
movlw MSG1
;movwf TXREG
call LCD_PrintString
call LCD_NewLine
movlw MSG2
call Delay1sec
call LCD_Init
call Delay10ms
movlw MSG3
call LCD_NewLine
;call Voltage
movlw MSG4
call Delay1sec
return
Do you setup the uart somewhere else in your code?. The pic's uart requires some setup code before you can start copying things to TXREG
Secondly, you should check bit TXIF of register PIR1 to see you are allowed to write new data to TXREG. This flag indicates the usart is ready for transmission.
Ooops, guess I missed copying some code-
LIST p=16F877
#include "p16f877.inc"
errorlevel 1, -302 ;Suppress bank 0 messages
; Memory Declarations
cblock 0x20 ; Start of general purpose memory
endc
ORG 0x000
Start:
goto Init ; Execute code
ORG 0x004
Interrupt:
goto Init ; Ignore interrupts
Init:
BANKSEL TRISA
movlw b'11111111'
movwf TRISA
BANKSEL TRISB
movlw b'11111111' ; All inputs including user buttons
movwf TRISB
BANKSEL TRISC
movlw b'11110000' ; LED lines as outputs
movwf TRISC
BANKSEL TRISD
movlw b'00000000' ; LCD lines all are outputs
movwf TRISD
BANKSEL OPTION_REG
movlw b'00000111' ; 0=PortB weak<7>,(Intedg<6>),(T0CS<5>),(T0SE<4>),(PSA<3>)256<210>
movwf OPTION_REG
;;;; Initialize UART
BANKSEL SPBRG
; Set up baud rate (9600)
movlw .129
movwf SPBRG
; Set up serial port
movlw 0x24
movwf TXSTA
BANKSEL RCSTA
; Enable port
movlw 0x90
movwf RCSTA
BANKSEL PORTA ; Normal bank again
Can't see anything wrong with the setup code at first glance
But you'll need to check TXIF before transmitting
Transmits W over the serial port
SerialTransmit
	   BANKSEL TXREG
		BTFSS	PIR1, TXIF		;Buffer empty?
		GOTO 	$-1				;no? then wait until it is
		MOVWF	TXREG			;Transmit W
		RETURN
