RS232+arrays
Asjad
Dear world,
Does anyone know how to pass an array through the serial port
I am using
PIC16F874
CCS COMPILER
If you know the soloution in hi-tech compiler, then that is okay
I thank you in advance
Regards
What do you mean an array? A variable array? Who is receiving it? Perhaps a loop will do it, loading the value into a variable and sending it then increasing 1 to read the next value and loop....
Ivancho
Here is what I haven't learned yet... I would like to recieve a few characters from the serial port and send a bunch back. I'm not sure how to work with this in the memory. If I want to recieve 3 characters first, I can store the first byte to some memory location, then I increment the address. I'm just not sure how to refer to an address rather than a number or literal. For this particular string I could refer to it in its exact location in the general registers.
Are there any routines for storing strings and sending them serially??
I would really like to move over to the PIC18 to get away from this paged memory but the web lacks many examples. At least its not too different.
In C to get a memory location instead of a value you use the & character in front of the variable
unsigned char var;
memorylocation = &var;
