RS232 with only 3V power supply
Exo
Active Member
I'm building a project wich involves a pic, and i want it to communicate to a pc using the serial port. Now this project runs on 2 AA batteries so it only gets 3V. My Max232 won't run with this (stops below 4.2V).
Does anyone have some other idea on how to communicate with rs232 levels with only a 3V supply?
I would suggest you check the RS232 specifications, it works at a lot less tha +/-12V - obviously you have no problems receiving from RS232, and your transmit can be +3V and 0V, which will probably manage OK.
I tried it, but it seems 3V is just a little too less, sometimes some bits are missed.
I found this yesterday, it uses the pc's own handshaking lines and swiches them back for a '1' or a '0'. Should have thought about it myself
