Hello
I'm using PIC18F67K22 with internal OSC 4MHz and CCS compiler ver
4.130. I have the RTCC clock selection used with (SOSC0 & SOSC1)
via crystal 32.768kHz.
I have a simple test program where I set the alarm for 10secs
and then wait to see if my LED will flash after 10secs. The process
then repeats itself as per my program.
However, I can not achieve this since my LED is not flashing
at will with the RTCC alarm. On its own, the LED does flash and i can
even set the flashing rate to any rate that i desire.
Please can someone help and suggest where i'm wrong in my code
below and how to achieve RTCC alarm.
Haseeb
Haseeb
#include <18F67K22.h>
#fuses INTRC_IO, NOWDT, NOBROWNOUT, MCLR
// Set Speed to 4Mhz
#use delay(clock=4000000)
#include <stdio.h>
int alarm_flag = 0;
#int_RTC
void RTC_isr(void)
alarm_flag = 1; //raise flag once 10secs lapse
void main(void)
delay_ms(500); //startup delay
enable_interrupts(INT_RTC); //enable RTC interrupts
setup_rtc(RTC_ENABLE); //enable RTC
while(true) //loop forever
setup_rtc_alarm(RTC_ALARM_ENABLE, RTC_ALARM_10_SECONDS, 0x08); //initiallize 10 sec alarm
while(alarm_flag == 0); //stay here until 10sec alarm
alarm_flag = 0; //reset flag
//flash to indicate 10sec alarm
output_high(pin_B4);
delay_ms(200);
output_low(pin_B4);
delay_ms(200);
delay_ms(200);
output_low(pin_B4);
delay_ms(200);
