RTCC Set
TucsonDon
I am a hobbyist and have a basic knowledge of C. I am trying to set up a call function to set the time on an rtcc. I have it set so that if a button is pushed for a set time it will call the function. I want to toggle between the HH:MM:SS with the "Set" button and then use a "up" or “down" to change the value. I was thinking of using a switch statement to toggle between but unsure how to setup.
I have also defined the following
volatile uint8_t Time[3]
volatile uint8_t stime[Time]
HH=Time[2]
MM=Time[1]
SS=Time[0]
i only know computers not mcu-s
use switch(index){case 0: ... break;default:index=0}
or use index=++index%3
_________________
? if you want to know how to access RTC built in or external - not how to organize the program structure - then post your equipment specs ?
  • togg-test.html.txt
I would cycle through the digits. On pressing set, read the time and set a flag to stop the clock from updating, display the time, set the 10s of hours flashing and set a counter to 0. You will need an ok button to move the digits along and up/down to change it. Once the counter reaches 4 you can write the time back to the RTC. You could use the set button to move to the next digit or, it you have an ok button, set could act as cancel.
So far this is what I have come up with:
Please let me know what you think
void TimeSet(void)
    while (sett!=30)
        TMR3_StartTimer();
        if(Set_GetValue()==Hi)stime=1;
        switch (stime)
            case 0:
                stime = 1;
                while(Set_GetValue()!=Hi); //wait for button or timer
                    if(Up_GetValue()==Hi & Pushed!=On) //up button pushed
                        Pushed=On;
                        HH=HH+1; //hour inc.
                        if (HH==13)HH=1;
                        sett=0;//reset time counter
                    if(Down_GetValue()==Hi & Pushed!On) //down button pushed
                        Pushed=On;
                        HH=HH-1; //hour deinc.+
                        if(HH==0)HH=12;
                        sett=0;
                    if(Up_GetValue()!=Hi|Down_GetValue()!=Hi)Pushed=Off;
                    //only inc or deinc one number @ a time
                if (Set_GetValue()==Hi)stime++;
                break;
            case 1:
                stime = 2;
                        Pushed=On;
                        MM=MM+1;
                        if (MM==60)MM=0;
                        sett=0;
                    if(Down_GetValue()==Hi & Pushed!=On) //down button pushed
                        Pushed=On;
                        MM=MM-1;
                        if(MM==-1)MM=59;
                        sett=0;
                break;
            case 2:
                stime = 3;
                        Pushed=On;
                        SS=SS+1;
                        if (SS==60)SS=1;
                        sett=0;
                    if(Down_GetValue()==Hi) //down button pushed
                        Pushed=On;
                        SS=SS-1;
                        if(SS==-1)SS=59;
                        sett=0;
                 if (Set_GetValue()==Hi)stime=1;
                break;
            default:
               if(sett == 30) return;
                //sett is advanced by timer to = 30 sec.
                //if no action is taken return to main
        if (sett == 30)return;
        //if no action is taken in 30 sec. return to main
[code/]
PIC18C Reference Manual ♦ 14.5 Timer1 Operation in Asynchronous Counter Mode ♦ If T1SYNC (T1CON register) is set, the external clock input is not synchronized. The timer continues to increment asynchronously to the internal phase clocks. The timer will continue to run during SLEEP and can generate an interrupt on overflow that will wake-up the processor. However, special precautions in software are needed to read/write the timer (Subsection 14.6.4 “Reading and Writing Timer1 in Asynchronous Counter Mode with RD16 = 0” ). Since the counter can operate in sleep, Timer1 can be used to implement a true real-time clock. The timer increments at the Q4:Q1 and Q2:Q3 edges. In asynchronous counter mode, Timer1 cannot be used as a time-base for capture or compare operations.
~about -- identifying the likely product , cant eval. your code coz "too lazy" to dig into MC-"X" specifics
the construction:
Pushed=On;
NB! may be a cause for confusing situations e.g. assuming system state
The MCU that I am using is the PIC18F45K22
My goal with "Pushed" was to only allow the variable to change once per button press.
http://www.flowgorithm.org/ may be for help as well as to slow things down -- at least it allows you to chart all possible system states
your code can be optimized as : (write one) subroutine for all time-record (array in your case) fields changes/updates -- as:
  • function usrIFx(step,modulo){var rr;if(step<0){rr=modulo}else{rr=0};return rr}
    function dec_inc_Date(TmFld,step,modulo){TmFld+=usrIFx(step,modulo)+step;TmFld%=modulo}
  • also setting it up as a software interrupt rather than the code branch
  • PS! i only hope i didn't pass ↑↑there↑↑ any mistakes !! -- as not too busy with progg'ing these days
    -- Now! with some example
    . . . and yet another (witch more than explains why i'm not too busy with progg'ing)
_________
i wonder the century when this "Coming soon" was written http://microchipdeveloper.com/8bit:he
attempting to get into the subject http://www.google.com/search?q=microchip+pic18+TMR0_StartTimer()+does+what+exactly+-confusion
←this search -- required to verify that 30s inactivity causes anything
i think i retire here
____________
BTW your current "code form" is easier to debug (you asked about other opinions . . . you can/should/may start compacting when the more space in micro is required)
  • togg-test2.html.txt
  • togg-test2v2.html.txt
