Hey, I am trying to convert my fog machine to a "fazer". The machine ATM uses a 240V piston type pump to get the juice from the container to the heater block. I know how real hazers work, and I know it wont be the same thing, but fazers are quite affective too. What i'm wondering, is if there is a way I can adjust how much juice gets to the heater. I cant use a valve, since its a pressure pump. I was thinking there had to be a way I could maybe slow the pump down abit. I dont think PWM would work, since you need 240V for the pump, and it runs on the 50hz frequency causing it to actually pump. I'm not sure voltage regulation would do it either, since its the frequency that determins how much/fast it pumps.
Any idea's?
