skeeterb
I saw a post on the electronic labs board, a suggestion to use salt water to etch a PCB instead of the chemicals normally used to etch PCBs. The URL for that post is https://www.electronics-lab.com/forum/index.php?topic=11940.0
skeeterb said:I saw a post on the electronic labs board, a suggestion to use salt water to etch a PCB instead of the chemicals normally used to etch PCBs. The URL for that post is https://www.electronics-lab.com/forum/index.php?topic=11940.0
skeeterb said:Tell me what y'all think
skeeterb said:hrmm, I wonder if replacing NaCL with NaOH would work, since Sodium Hydroxide is a kind of salt. That way instead of Chlorine gas coming off the one side of the cell, it would be Oxygen, but that may cause a problem in a way, since oxidation is the enemy when it comes to any electronic application. Tell me what y'all think
Glyph said:Good to see you're thinking, but sodium hydroxide is not a good idea. The hydroxide will raise the pH of the solution and this will cause copper hydroxide to precipitate out as you etch. The insoluble copper hydroxide will disrupt the flow of solvent to the copper surface and give you an uneven etch. If it adheres really hard it might even stop further etching (although i'm not 100% sure of that).
If you're really hell-bent on avoiding chlorine gas then use sulfuric acid solution instead of NaCl. Sulfuric acid (also known as battery acid) will keep the pH low avoiding the hydroxide problems. sulfuric acid itself though is corrosive so you might want to avoid getting it on your hands. Although now you've traded one problem for another: toxic gas vs. corrosive solution![]()
Glyph said:come to think of it. maybe someone should make a sticky on PCB etching, both commerical products and homemade.
Glyph said:The peroxide/acid etch is very weak and i'm only reccomending it if you have NO other choices. its not good for a total etch because unless you can get your hands on 98% sulfuric acid and 30% hydrogen peroxide (drug stores only sell 3%) you won't be able to make a strong enough solution to etch the bulk copper in a reasonable amount of time (you'll be burning plenty of $$$ making baths to keep etching every few hours until its done). Thus the electrolytic etch is a cheaper primary etch and this solution is for scrubbing etch.
