Here's a quickie
I will connect colour sensor with Uc and uc wil speech like robots ''Its REd..''I never thought I would say this, but now you are giving just a little bit too much info.. "sex audio".
OK, can what memory device can be used pendrive/EEPROM 24xx series/ memory card??
Don't even consider a USB drive - VERY, VERY difficult to drive, as you need a processor with a USB master (almost all USB capable processors are USB slave only).
Hi ,
is there any possibilities to save small few sex audio in micro controller like Pic16f877a and how, will it work??
He meant "few seconds". The letter "c" can be confused with "ts", "x" and "kh".
Anyway, if the user needs to put wave files inside the SD-Card with the computer, he need to put the FAT16 driver in the microcontroller too. That, and that layer is not easy to write, and consumes a lot of ROM and RAM inside.
Or, just use the "WTV-020" modules.![]()
OK Brian, now I see. Languages were never one of my strong points..
Thanks for the help
Regards,
tvtech
I found lot of link using 877a as audio player.....
Is there any other way then using this module??
can we use Two-wire Serial EEPROM
Difficult to say without knowing exactly
