schematic
gotay
I search a schematic of JENSEN KCD-9860
AM/FM CD PLAYER.
THANX
It's rated at 160 Whats.
Did you try to get more than 60 Watts out of it?
I not try get more than 60w out.
total system power = 160w
power output= from: 2 x 40w
rear: 2 x 40w
problem: (no audio) may b blow the audio output transistor
model= jensen KCD-9860
thanx: audioguro for you help
Dude, you need to give us more information to go on than what you've said so far - sheesh! Are we supposed to read your mind? Does the unit's display light up? If it has preamp outputs, is there audio coming out from it? Could be any one of a number of possible problems that can cause no audio output to the speakers.
The 40W per channel is Peak power. Peak power is just double the real RMS continuous power which is 20W per channel. The 20W per channel is with the amplifier clipping its head off producing horrible-sounding 10% distortion. It is about 15W per channel without clipping.
