hydrocynus
This is a really nice forum!
Ok. I am a Ph.D. researcher and I do not know much about electronics.
I need to mix water in a sealed incubation chamber (sort of canister). I have a magnetic stirrer, that is placed underneath the incubation chamber and which rotates a magnetic stirrer bar inside the chamber.
The problems I have are:
- the speed is not constant (the stirrer would speed up at time, or even stop for a couple seconds)
- the speed, even at the lowest setting is too fast.
So, I would like to make my own magnetic stirrer. (A magnetic stirrer is just a rotary motor, with a controller that rotates a magnet, the stir bar is also a magnet and is placed inside a container. Once the rotary motor spins, it spins the stir bar as well).
I have found sources to buy magnetic bars.
I would like to buy a 12 V DC rotary motor (I believe a gear head one is probably the cheapest, cheaper than a stepped motor) coupled with a controller (I believe a potentiometer would work) so that I can set the rpm between 1-60 rpm.
I do not know what I need as a potentiometer? What resistance should it have?
Any links welcome. I generally buy from jameco, but other links are welcome.
Thank you immensely.
Serge
BTW. there is that motor (probably high rpm), but the controller could be taken and assembled to the low rpm motor.. very cheap.
Heavy Duty 12VDC Motor with Regulator-The Electronic Goldmine
Here are some potentiometers:
Standard Potentiometers-The Electronic Goldmine
Serge
