Scrolling readout on LCD?
karenhornby
Problem with Scrolling line on LCD
I've got this code which SHOULD scroll the words "PRESS THE BUTTON" IF PORTB.1 = 1 AND PORTB.4 = 1 (temp triggers from temp sensors) AND IF PORTB.6 = 0 (pushbutton) AND PORTD.1 = 0 (Main POWER still active) but when I try compiling it, it gives the error *** Variable ' LCDIN ' not defined! ***
any suggestions?
Also it SHOULD play an ANNOYING morse code dot-dash sound for half a second before playing the star wars theme sound while scrolling, can anyone check and see if I've used the sound command correctly please?
The sound will drive a small loudspeaker or piezo sounder through a transistor from PORTD.1 "HOPEFULLY"! which would be loudest small speaker or piezo sounder?
The code for the sound output is a little messy as for some reason I couldnt get the FOR and IF commands to work to make the first bit of sound loop 5 times before it played the 2nd section
DEVICE = 16F877		'  PIC16F877 PICmicro
	XTAL = 4				' With a 4MHz crystal
' Define LCD pins
Define  LCD_DREG        PORTD
Define  LCD_DBIT        4
Define  LCD_RSREG       PORTE
Define  LCD_RSBIT       0
Define  LCD_EREG        PORTE
Define  LCD_EBIT        1
' Alias pins
RST     var     PORTC.0         ' Reset pin    'external DS1620
DQ      var     PORTC.1         ' Data pin      'external DS1620
CLK     var     PORTC.3         ' Clock pin     'external DS1620
' Allocate variables
temp    var     word            ' Storage for temperature
        Low RST                 ' Reset the device
        ADCON1 = 7              ' Set PORTA and PORTE to digital
        Low PORTE.2             ' LCD R/W line low (W)
        Pause 100               ' Wait for LCD to start
        Lcdout $fe,1, "DIESEL"
		Lcdout $fe,$C0, "Temp in degrees C"  ' Display sign-on message
		Define LCD_RWREG PORTC ' which port LCD RW is connected to
        Define LCD_RWBIT 2 '  which bit RW is connected to
		LcdCols con 20     ' number of Columns in your LCD
		' Software variables
        sc_rol var byte
        CounterA var byte
        DataX var byte
input PORTB.1   'Input from DS1620 in Thermostat mode (only HIGH or LOW)
output PORTB.2 'OUTPUT to Solenoid 1 FUEL SUPPLY
input PORTB.4  ' Input from DS1620 in Thermostat mode (only HIGH or LOW)
output PORTB.5 'OUTPUT to Solenoid 2  FUEL RETURN
input PORTB.6   'INPUT from Pushbutton Switch
output PORTC.2 ' output to R/W on LCD panel
input PORTD.0  'input to check MAIN power to circuit still alive
output PORTD.1 'OUTPUT TO WARNING SIREN
MAIN:
high PORTB.0	'toggle the clock pin.
    Pause 10		'the conversion will be complete
    Low PORTB.0		'before the inputs are read further down.
    ' Temploop to read the temperature and display on LCD
	TempLoop:
    RST = 1                 ' Enable device
    Shiftout DQ, CLK, LSBFIRST, [$ee]       ' Start conversion
    RST = 0
    Pause 1000              ' Wait 1 second for conversion to complete
    RST = 1
    Shiftout DQ, CLK, LSBFIRST, [$aa]       ' Send read command
    Shiftin DQ, CLK, LSBPRE, [temp\9]       ' Read 9 bit temperature
    RST = 0
    ' Display the decimal temperature
    Lcdout $fe,$C0,  dec (temp >> 1), ".", dec (temp.0 * 5), " degrees C"
     IF PORTB.1 = 1 AND PORTB.4 = 1 THEN  ' check to make sure both temperature inputs from DS1620's are HIGH
        IF PORTB.6 = 0 AND PORTD.1 = 0 THEN ' check to see if switch on PORTB.6 is pressed of not AND IF main power is turned off
            LOW PORTB.2    'switch fuel to diesel
            HIGH PORTB.5   'fuel return goes to diesel tank
			LcdOut $FE,$C0, "PRESS THE BUTTON"
            Pause 250  ' leave it on the screen long enough to see
                       ' before incrementing along the line
        For sc_rol=1 to $C0 ' scroll one character to the right routine
        For CounterA=20-1 to 1 step -1' work backwards along the line
                                               ' from right to left
            LcdIn $C0+CounterA-1,[DataX]' Read one character from column x-1...
            LcdOut $FE,2+CounterA,DataX '.and write it to the adjacent location
        Next CounterA   ' and do it for the whole line (less one column)
         If sc_rol=1 then LcdOut $FE,2," " ' don't forget I need to add
'a space at the beginning  of the line, but you only ever need to do this once
           Pause 250  ' Pause for effect...
       Next sc_rol
	    Sound PORTD.1,[120,05] 'DI sound
		  PAUSE 100
                SOUND PORTD.1,[120,20] 'DAH sound
		  PAUSE 100
		  PAUSE 100
		  PAUSE 100
		  PAUSE 100
		  PAUSE 100
               Sound PORTD.1,[97,80,108,80,105,20,104,20,101,20,113,80,108,80,105,20,104,20,101,20,113,80,108,80,105,20,104,20,105,20,101,80]
                                               'SHOULD play an ANNOYING "DI" DAH" morse code kinda sound then play the starwars tune
     else
	    IF PORTB.6 = 0 AND PORTD.1 = 1 THEN     ' IF pushbutton switch on PORTB.6 AND Main power is ON
            HIGH PORTB.2  'fuel switches to veg oil
            HIGH PORTB.5  'fuel return goes to veg oil tank
	   Lcdout $fe,2, "Veg-Oil"
	else
            HIGH PORTB.2  'switch fuel to Diesel
            LOW PORTB.5   'keep fueel return to OIL tank
            Lcdout $fe,2, "FLUSHING"   ;clears Injection pump of Veg-Oil
            Pause 10000   'PAUSES for TEN SECONDS then (HOPEFULLY) SETS OUTPUTS B2 and B5 LOW
            Lcdout $fe,2, "Diesel"
            LOW PORTB.5   'switch car to Diesel Fuel
            LOW PORTB.2   'switch fuel return to Diesel Fuel
			While PORTB.6=0        'wait for button to be pressed again
          WEND
		endif                      'this is short for while end
      endif
    endif
    Goto MAIN           ' Do it forever
