I've been using the 4066N analog switch in a number of projects lately. My projects involve switches that are common ground; they are High when not pressed, and low when pressed. The 4066N enables the analog switch when the control line is high, and disabled them when low; the opposite of what I need.
The only other 'active low' analog switch I've found is the MAX4611. It works great, but is costly ($1.50 vs a 4066N's .50) and not as readily available. Speed, On resistance, etc, are not much of a concern, so economical options are better than high performance ones.
Is there a 'standard' analog switch IC, available in DIP, that enables the switches on low?
