I hope they haveStyx said:if yr DMM has a diode-check AND the FET you have has an intrisnic diode you can do a diode-check on the pins to figure out the source and drain pins
from that you know that the 3rd must be the GATE and equally via the conduction of the diode-test you know which one is DRAIN and which one is SOURCE
I know the site, but I still can't find the datasheet.Tryed even on some Rusian sites <lol> cause some of them are made in Soviet Union.audioguru said:Look at the pins on the datasheet. www.datasheetarchive.com
Useful tip...bot no datasheet foundStyx said:a tip for finding datasheets... Google
say you need to find the datasheet for: IRFR024 (an N-type FET)
Type this into google
IRFR024 filetypedf
Since most datasheets are pdf documents, this will only return pdf files, 99% of the time it will return a link to the datasheet (normally a good link in the top5). Only failed me once this method out of 1million uses
Well...i got a smal bag full of those thingies.audioguru said:Why not use parts that are made by companies that you know are good and parts that are common and cheap?
