vne147
Hello everyone. I am seeking advice on the design of a circuit that will go inside of a Halloween costume I’m making. The circuit basically blinks 75 LEDs, 9 at a time in sequence to give the illusion of traveling light. I am using a 555 timer that sends pulses to two 74HC4017 decade counters. The 4017 outputs turn transistors on and off which turn the LEDs on and off. I am planning on powering the circuit off of 8 AA batteries wired in series so I have an approximate supply voltage of 12 V. All the ICs, transistors, and LEDs draw about 200 mA at 12V. I prototyped the circuit already and it works great off of the 8AAs with no voltage regulator or caps at the V+ side. Pretty straight forward so far however, I am also planning on occasionally powering an addition 40 LEDs all at once that I will turn on and off through a switch. The additional 40 LEDs will be powered off of the same 8 AA batteries. When the 40 LEDs are lit they will draw about 1 A. OK so here is my question. When I turn on the 40 additional LEDs will the sudden increase in current draw adversely affect the rest of the circuit? I want the 555 timer and 4017s to keep working the whole time. Should I add a voltage regulator to the circuit for the logic portion? Could I get away with just adding a few caps to the supply voltage side of the logic circuit? If so, how would I go about selecting the proper size caps? Should I add any diodes? Any advice or suggestions are greatly appreciated. Please let me know if you need more information and I can post a schematic or the .sch file. Thanks.
