Hello all.
I'm currently finishing an HNC in Mechanical Engineering. As part of the course, I am designing a wireless tachometer. In hindsight, I should have chosen something that is not so electronics based - my knowledge is not great. I work for a Industrial Fan manufacturer so I thought it would be good to make something that I could use at work.
Anyway, I found a circuit for a 7-segment LED counter. http://www.aaroncake.net/circuits/counter.htm I've got the parts to make this and I'm ready to crack on. The part that I am unsure about is the sensor... I've found a sensor from a local stockist. **broken link removed**
This only has a 120mm range though, with a peice of 200x200 white paper. I'd like a lot bigger range, Pepperl & Fuchs make a 2 metre range one but this is expensive. It has to be the diffused type as I cannot mount a reflector on a fan blade. Ideally the target area should be less than 100x100mm... Anyone know of anything? As these are to be used to measure the speeds of fans up to 2.5M diameter, I would like one that would work from 2 metres away - although to be honest I would be happy with one that will only measure a few inches - this would not fail my project I would just not use it for measuring fans, it'll just be used occasionly for lathes. I'd also like to be able to read speeds of up to 3000RPM, although again this is only a wish.
The main bit that I am unsure about is connecting it to the circuit. I know it will be easier to connect a N/O type but I can only really see ones that are PNP or NPN that are suitable.. Would this be hard to connect to my circuit?
Thanks if anyone can help, I would rather not join a forum and ask a question straight away but hopefully I'll be able to help someone else on a part of the forum somewhere in return!
Pete.
Pete.
