mozikluv
i have been mulling this question for quite sometime now but have never come up to it, but here goes. i know the best approach is to go direct to what you need but there are situations where what you have available can't satisfy the need. i will definitely try this approach but before i do that i would like to solicit whatever comment, suggestions or criticisms to this idea.
situation 1: 2 units of 0-12v 1A transfo to be connected in series;
Q1. what will be the voltage measured end to end?
Q2. what will be the voltage measured from one end to the series connection.
Q3. What will be the available current?
Q4. is it necessary that the secondary output voltage be identical?
situation 2: 2 units of 0-12v 1A transfo or 2 units of 12-0-12v connected in parallel.
Q1. is it also necessary that the output voltage of the secondary are identical?
