serin/out, pic to pic communications
Jerran
Im having trouble with a simple project. Im wanting to send data between 2 pics using the serin/serout commands in picbasic pro. Basically Im wanting the transmitting pic to send data out serially when a button is pressed, the reciever will turn on a led(for testing purposes, in application it will store the data sent) while the button is pressed.
Are there any obvious errors Im missing?
B0 VAR byte
input porta.2
output porta.3
'Transmitter
main:
B0 = 0
button porta.2, 0, 255, 255, B0, 1, transmit
goto main
transmit:
serout porta.3, 4, ["A", 125]
goto main
end
'Receiver
B0 VAR byte
output porta.2
input porta.3
main:
B0 = 0
serin porta.3, 4,["A"], B0
if B0 = 125 then
	high porta.2
else
low porta.2
endif
goto main
end
Well... what errors are you getting?
I would change the INPUT commands, OUTPUT command for:
B0 VAR byte
TRISA = %00100  ' makes porta.2 input all others output
'Transmitter
main:
B0 = 0
goto main
transmit:
goto main
end
'Receiver
B0 VAR byte
TRISA = %0100  ' makes porta.3 input all others output
main:
B0 = 0
if B0 = 125 then
   high porta.2
else
low porta.2
endif
goto main
end
I would try and see what it is sending by checking the output in a computer. Also make sure that you are connecting the transmiting and receiving pins right. What oscillator are you using, make sure that you define it if it is something else than 4Mhz.
Ivancho
