ombrastein
Im working on a hexapod. I need to know if any of the servo motors(standard hitech 422 and 485) get heavly loaded. Im thinking to use this to sense if any legs crash into an obstacle, kinda like a bumperswitch. Pluss it would be good to measure automaticly exactly what load the servos are pulling.
The idea i have is to use a 0.1 ohm resistor between motors and ground, thus generating a small voltage drop over this ersistor. the servos never pull more then one or two amps, so teh voltage drop is realy insignificant.
Then i can use an A/D, either directly or thru a differential amplifier to measure digitaly the load each motor is sensing (basicly measuring the current).
Im thinking i will need to measure diferentialy, and stick the wires as close to the resistor as posible, so the internal resistanse of the wires dont contaminate my emaruments.
Any thoughts or ideas about this? Anyone ever done anything similar?
Cheers,
Magnum
Cheers,
Magnum
