seven segment 3 digit counter
Koba Late
The code looks fine. When you say it's not working, what is it doing?
One thing, which is not your problem but may cause problems later, the temporary variables (w_temp etc) need to be in the common area at 0x70 - 0x7f.
For anyone interested, here is the tidied up version.
;7 segment LED display - count up from zero
        LIST    p=16F877a    ;tell assembler what chip we are using
include        "P16F877a.inc"         ;include the defaults for the chip
        ERRORLEVEL 0,-302    ;suppress bank selection messages
        cblock    0x20        ;start of general purpose registers
count                    ;used in looping routines
count1                    ;used in delay routine
counta                    ;used in delay routine
countb                    ;used in delay routine
tmp1                    ;temporary storage
tmp2
p_temp                    ;save register
s_temp                    ;save register
w_temp                    ;save register
tens                    ;tens storage
ones                    ;ones storage
        endc
SEG_PORT    Equ    PORTB        ;7 segment port
SEG_TRIS    Equ    TRISB
        org    0x0000
        goto    Initialise
;     Interrupt routine
; Interrupt routine handles TMR2 which generates a 1ms tick
;    Interrupt vector
        ORG    0x0004
INT
        movwf    w_temp        ; Save W register
        swapf    STATUS,W    ; Swap status to be saved into W
        movwf    s_temp        ; Save STATUS register
        movfw    PCLATH
        movwf    p_temp        ; Save PCLATH
        btfss    PIR1,TMR2IF    ; Flag set if TMR2 interrupt
        goto    INTX        ; Jump if not timed out
; Timer (TMR2) timeout every 1 milli second
        bcf    PIR1,TMR2IF    ; Clear the calling flag
        btfss    SEG_PORT,7    ;check which LED was last
        goto    Do_tens
        movfw    ones
        andlw    0x0F        ;make sure in range of table
        call    LED_Table
        andlw    0x7F        ;set to correct LED
        movwf    SEG_PORT
        goto    INTX
Do_tens        movfw    tens
        call    LED_Table
        iorlw    0x80        ;set to correct LED
        movwf    SEG_PORT
INTX
        movfw    p_temp
        movwf    PCLATH        ; Restore PCLATH
        swapf    s_temp,W
        movwf    STATUS        ; Restore STATUS register - restores bank
        swapf    w_temp,F
        swapf    w_temp,W    ; Restore W register
        retfie
LED_Table    ADDWF    PCL , f
        RETLW    b'10001000'    ;0
        RETLW    b'10111011'    ;1
        RETLW    b'11000001'    ;2
        RETLW    b'10010001'    ;3
        RETLW    b'10110010'    ;4
        RETLW    b'10010100'    ;5
        RETLW    b'10000100'    ;6
        RETLW    b'10111001'    ;7
        RETLW    b'10000000'    ;8
        RETLW    b'10110000'    ;9
        RETLW    b'11111111'    ;blank
Initialise    movlw    0x07
        movwf    CMCON        ;turn comparators off (make it like a 16F84)
        bsf    STATUS,RP0    ;select bank 1
        movlw    b'00000000'    ;Set port data directions, data output
        movwf    SEG_TRIS
        bcf    STATUS,RP0    ;select bank 0
;    Set up Timer 2.
;movlw    b'01111110'     ; Post scale /16, pre scale /16, TMR2 ON
;uncomment previous line, and comment next line, to slow multiplexing speed
;so you can see the multiplexing happening
        movlw    b'00010110'    ; Post scale /4, pre scale /16, TMR2 ON
        movwf    T2CON
        movlw    .249        ; Set up comparator
        movwf    PR2
        bsf    PIE1,TMR2IE    ; Enable TMR2 interrupt
; Global interrupt enable
        bsf    INTCON,PEIE    ; Enable all peripheral interrupts
        bsf    INTCON,GIE    ; Global interrupt enable
        clrf    tens
        clrf    ones
Main
        call    Delay255
        call    Delay255
        call    Delay255
        call    Delay255
        incf    ones,    f
        movf    ones,w        ;test first digit
        sublw    0x0A
        btfss    STATUS, Z
        goto    Main
        clrf    ones
        incf    tens,    f
        movf    tens,w        ;test second digit
        sublw    0x0A
        btfss    STATUS, Z
        goto    Main
        clrf    tens
        goto    Main        ;loop for ever
Delay255    movlw    0xff        ;delay 255 mS
        goto    d0
Delay100    movlw    d'100'        ;delay 100mS
        goto    d0
Delay50        movlw    d'50'        ;delay 50mS
        goto    d0
Delay20        movlw    d'20'        ;delay 20mS
        goto    d0
Delay5        movlw    0x05        ;delay 5.000 ms (4 MHz clock)
d0        movwf    count1
d1        movlw    0xC7        ;delay 1mS
        movwf    counta
        movlw    0x01
        movwf    countb
Delay_0
        decfsz    counta, f
        goto    $+2
        decfsz    countb, f
        goto    Delay_0
        decfsz    count1    ,f
        goto    d1
        retlw    0x00
How to write assembly for pic 628a to count object with three 7 segment display.please help. I'm a student.
MOD EDIT!! Created your own thread
Probably not a good way to learn having it all done for you, however this might be of use to you.
