Seven segment display and Arduino Soldering Iron Driver
123mmm
Hi! I found the attached code on a internet article but I modified it because in the original code, the Thermocouple was read by LM358, and now I wanted to read it by MAX6675 module.
If I read the thermocouple (MAX6675) in the loop() function, then the read value does not refresh, but if I read the thermocouple as it is in the code below, then it works.
I read on a forum, that the MAX6675 can be read by Arduino only 4 times/ second, could this be the problem ?
Please have a look at the code and schematic and tell me what you think ?
C:
#include <PID_v2.h>
#include <max6675.h>
int thermoDO = 12;
int thermoCS = 10;
int thermoCLK = 13;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
//protection
int relay_pin = A5;
int led_pin = 8;
//This array contains what segments need to be turned on to display numbers 0-9
byte const digits[] = {
  B00111111, B00000110, B01011011, B01001111, B01100110, B01101101, B01111101, B00000111, B01111111, B01101111
int digit_common_pins[] = {A2, A3, A4}; //Common pins for the triple 7-Segment LED display
int max_digits = 3;
int current_digit = max_digits - 1;
unsigned long updaterate = 700; //Change how fast the display updates. No lower than 500
unsigned long lastupdate;
int temperature = 0;
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
double heaterTemp;
//Define the aggressive and conservative Tuning Parameters
double aggKp = 4, aggKi = 0.2, aggKd = 1;
double consKp = 1, consKi = 0.05, consKd = 0.25;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);
void setup()
  DDRD = B11111111;  // sets Arduino pins 0 to 7 as outputs
  for (int y = 0; y < max_digits; y++)
    pinMode(digit_common_pins[y], OUTPUT);
  //We do not want to drive the soldering iron at 100% because it may burn, so we set it to about 85% (220/255)
  myPID.SetOutputLimits(0, 220);
  myPID.SetMode(AUTOMATIC);
  lastupdate = millis();
  Setpoint = 0;
  pinMode(led_pin, OUTPUT);
  pinMode(relay_pin, OUTPUT);
  digitalWrite(led_pin, LOW);
  digitalWrite(relay_pin, LOW);
  delay(1000);
  digitalWrite(relay_pin, HIGH);
void loop() {
  if (millis() - lastupdate > updaterate) {
    //  Read temperature
    heaterTemp = thermocouple.readCelsius();
    Input = (0.779828 * heaterTemp) - 10.3427;
    //Display temperature
    if (isnan(heaterTemp) or Input >= 432) // No TC Connection OR over-temperature
      while (true) {
        digitalWrite(11, LOW);
        PORTD = B00000000; // turn off the dislay
        digitalWrite(led_pin, HIGH); //turn on the warning red led
    temperature = Input;
  //Read setpoint and transform it into degrees celsius(minimum 150, maximum 350)
  double newSetpoint = analogRead(A1);
  newSetpoint = map(newSetpoint, 0, 1023, 150, 400);
  //Display setpoint
  if (abs(newSetpoint - Setpoint) > 3) {
    Setpoint = newSetpoint;
    temperature = newSetpoint;
  double gap = abs(Setpoint - Input); //distance away from setpoint
  if (gap < 10)
  { //we're close to setpoint, use conservative tuning parameters
    myPID.SetTunings(consKp, consKi, consKd);
  else
    //we're far from setpoint, use aggressive tuning parameters
    myPID.SetTunings(aggKp, aggKi, aggKd);
  myPID.Compute();
  //Drive the output
  analogWrite(11, Output);
  //Display the temperature
  if (temperature < 50) {
    show(50); //shows 50 on the display if the temperature is below 50 C
  else
    show(temperature); // display the read temperature on the display
void show(int value) {
  int digits_array[] = {};
  boolean empty_most_significant = true;
  for (int z = max_digits - 1; z >= 0; z--) //Cycle through each digit
    digits_array[z] = value / pow(10, z); //We now take each digit from the number
    if (digits_array[z] != 0 ) empty_most_significant = false; //Do not display leading zeros
    value = value - digits_array[z] * pow(10, z);
    if (z == current_digit)
      if (!empty_most_significant || z == 0) { //Check to see that we do not have leading zeros and display the current digit
        PORTD = digits[digits_array[z]]; //Remove ~ for common cathode
      else
        PORTD = B00000000;
      digitalWrite(digit_common_pins[z], HIGH);//Change to LOW for common cathode
    } else {
      digitalWrite(digit_common_pins[z], LOW);//Change to HIGH for common cathode
  current_digit--;
  if (current_digit < 0)
    current_digit = max_digits; //Start over
