sonar_abhi
I am coding SSD display using 2 cascaded shift registers. I am using a mikroC for PIC compiler. I can display a static sequence of numbers upto 4 digits with my code
If I add more digits to the array4[], say upto 9, I will need to scroll the digits to the left sequentially. I tried shifting the array by
I hoped that this code will left shift the array and the display will scroll, but all I am getting is a jumbled up display. If I add a delay, I can see that the numbers are getting displayed but without scrolling.
Is the basic algorithm faulty or can it be used by modifying the code?
#define SHIFT_CLOCK PORTB.F1 //Clock Connection of 74HC595 SSD Driver
#define SHIFT_LATCH PORTB.F3 //Latch Connection of 74HC595 SSD Driver
#define SHIFT_DATA PORTB.F2 //Data Connection of 74HC595 SSD Driver
char array4[4] = {6, 91, 79, 102}; //Display 1234 on SSD
char digit[4] = {0xFE, 0xFD, 0xFB, 0xF7}; //Switch on the SSD digits one by one
char i,j,temp,flag1,flag2;
void InitTimer0()
OPTION_REG = 0x86;
TMR0 = 6;
INTCON = 0xA0;
void latch595()
SHIFT_LATCH = 1;
Delay_us(1);
SHIFT_LATCH = 0;
void shiftdata595(unsigned char _shiftdata)
int i;
unsigned char temp;
temp = _shiftdata;
i=8;
while (i>0)
if (temp.F7==0)
SHIFT_DATA = 0;
else
SHIFT_DATA = 1;
temp = temp<<1;
SHIFT_CLOCK = 1;
SHIFT_CLOCK = 0;
i--;
void Interrupt()
if (TMR0IF_bit)
TMR0IF_bit = 0;
TMR0 = 6;
flag1 = 1;
flag2 = 1;
void main()
TRISB = 0;
TRISC.F1 = 1;
InitTimer0();
while (1)
if (PORTC.F1==0)
if (flag2==1)
shiftdata595(digit[i]);
i++;
if(i==4)
i=0;
if (flag1==1)
shiftdata595(array4[j]);
latch595();
j++;
if (j==4)
j=0;
else if(PORTC.F1==1)
shiftdata595(0);
shiftdata595(0);
latch595();
temp = array4[0];
for (n=1; n<8; n++)
array4[j-1] = array[j];
array[9] = temp;
