Hi all, I bought a us Philips DAC960 converter on ebay for use here in the Netherlands. It works fine on a power converter. But the converter transforms european 220/2230V 50hz to 120 !!!50hz!! I want to modificate the main supply to 230volts !!!60hz!!!
The american en europeans are I beleive same in every other expect. The print is the same and can be used with 120 volt fuses and 220 volt fuses. So to be sure I need a severice manual for a DAC960 US model Philips DA960/17R so that I can compare the specs with my service manual for the european model!
Pls, anypone??
Pls, anypone??
