DaKandEKid
I have three chips which could run off a 13Mhz clock.
At least two of the three can be driven by a reference frequency. Meaning they don't have to drive a crystal they can be hooked up to an oscillation directly.
I could use one chip to drive the crystal and then i was thinking i could buffer the signal through an inverter or basic emitter follower bjt circuit to the other two chips.
Questions:
1) I know this will work but is it an okay design practice. One problem you will run into is that the crystal will be further away from the chips. I have a radio chip, an external demodulator chip, and a microcontroller. I was thinking if the crystal was close to the radio chip the PIC would probably wouldn't be affected by the crystal traces being a little longer.
2) Anything else that would be affected? Perhaps it'd be more susceptible to temperature?
Thanks,
~blake
Questions:
Thanks,
~blake
