I am using a micro stamp (BS2) to monitor an RS-232 input and then perform certain functions based on the input data received. It never needs to transmit serial data. The circuit does have a push button that will provide the +V input as an output (through a 10K resistor) when pressed.
I only have 5 pins that I can use (on an M12 connector). The entire circuit will be encapsulated in a potting compount.
During normal operations, this is enough for +V, Rx, Gnd, and the pushbutton output. However, I would also like to be able to reprogram the processor which requires the Tx line and the DTR (ATN) lines--which makes 6.
Because I only have 5 pins available on my connector, I would like the pushbutton output line to serve double duty and be used as the RS-232 Tx line during programming (and I will not press the button during this time).
How do I protect the idle RS-232 output from any effects from +V being applied by the pushbutton. I at first thought of using a diode but remembered that RS-232 generates +/- 12 volts and so that would not work.
I would have two different cables--the normal cable (no pin 5) and a special programming cable (that has the DTR signal connected to pin 5). Of course, pin 2 will be common to the pushbutton and the Tx line respectively.
One more thing... I have almost no room on the board. I.E., no room for a RS-232 transceiver dip.
Any ideas?
Thanks,
Dale
Any ideas?
Thanks,
Dale
