Shunt reference and Series reference
Arunmurugesh
Hi All,
I am currently selecting a voltage reference IC, to provide an external reference to an ADC. I am not sure whether to choose a shunt voltage or series voltage reference. Kindly provide your valuble thoughts on this regard. Thanks in advance.
Keep Sminling,
Best regards,
Murugesh.K
Hi All,
Keep Sminling,
Best regards,
Murugesh.K
hi,:)
Do you mean shunt or series with ref to the ADC or the way the Vref is generated.?
The way the reference is generated. A series voltage reference Ic or a shunt voltage reference IC.
A common way is to use a zener diode or a voltage reference ic to generate the Vref.
Example: a resistor to a dc supply rail connected to a zener or Vref ic.
The ref voltage taken from the junction of the resistor/zener to the ADC.
I suppose that could be classed as a series ref.?
What would you consider a shunt ref.?
Your question is a little ambiguous.???
This appnote explains the differences between series and shunt. The selection depends on you application.
