Wrote a nice simple program, for a project at work - a simple interrupt driven pulse counter/divider with the processor in sleep most of the time, looking for five plus years battery life (as it will be potted in resin).
Used a little 8 pin PIC, 16F18313 - does everything I need, and I set it up using the MCC (to avoid the bother of getting the clock at the right speed).
For those who haven't used the MCC, it gives you a number of macros for enabling and disabling interrupts, commented out in the code, and you enable them as required.
Unfortunately, when I built it up and ran it, nothing happened? - so I was initially a bit baffled, then noticed my mistake:
Removed the // on the wrong line
![banghead :banghead: :banghead:](/styles/default/xenforo/smilies/banghead.png)
// When using interrupts, you need to set the Global and Peripheral Interrupt Enable bits
// Use the following macros to:
// Enable the Global Interrupts
INTERRUPT_GlobalInterruptEnable();
// Enable the Peripheral Interrupts
//INTERRUPT_PeripheralInterruptEnable();
// Disable the Global Interrupts
INTERRUPT_GlobalInterruptDisable();
// Disable the Peripheral Interrupts
//INTERRUPT_PeripheralInterruptDisable();
