simple 1 shot
the_mog
Hi All,
I am trying to find a simple 1 shot / monostable circuit
it needs to be a small as possible..
I basically need it to reset another circuit. this is done by switching off power to the second circuit for 3 sec's
however once power is applied to the new circuit it will stay powered for up to 3 hours, so all the monostables i have seen dont seem to do the trick
any help will be great
K-
You have not provided enough info. It is not so simple.
What triggers the 3 second period? Button? Interruption of power? Turn-on of power?
What is the power supply? Voltage? How much standby current can the timer draw?
How does the 3 sec timer switch power to the second circuit? High-side? Low-side? How many amps?
flip flops toggle circuits, then you can put a timer/counter on the trigger and reset latches
