armadacd55
dddddddddddddd
Cheers again for the help but using propper resistor values didnt work.
Of course using proper resistor values alone won't make your circuit work, you need to design it properly for that. Using real resistor values just means you'll be able to build it without having to connect loads of resistors in series or parallel to get the correct values.Cheers again for the help but using propper resistor values didnt work.
Why did the schematic disappear?
