Simple DC motor reversing diagram
greathouselabs
Hello,
I hoping that one of you might have a simple way to reverse a 12 DC motor using a relay and micro switches.
I am building a Halloween project , I need to trip a switch and have the dc motor pull a prop 10 feet one way and stop on a micro switch.
When another switch is pressed it would reverse the motorand go back to the starting micro switch.
Any simple ideas?
Place where I could find a schematic?
Lance
You are looking for an "H-bridge" (except instead of the normal MOSFETs, you replace it with relays).
I think this will work...a relay version of an H-bridge. The variation from your original request is that the "direction" is started or changed with a two position DPDT toggle switch. Flipping the direction switch during transit will reverse direction of the motor.
Ken
Lance,
You are basically wanting the same circuit that older less sophisticated automotive power windows use. The diagram at the link below is a very straight forward schematic of that circuit, without the limit switches, which can easily be installed in both the "up wire" and "down wire". It uses a coupla standard automotive relays that can be purchased at any auto store.
You can view that diagram here...
Lance,
You are basically looking for the same circuit as the older, less sophisticated setup for an automobile power window setup. This link shows that (easy to follow) circuit without the limit switches which, of course, would be placed in the "up wire" and "down wire". All that is required is the switch, a coupla automotive 5 pin automotive relays and your limit switches.
