Simple peripheral electronic circuit question
jasonbe
Hi. One of the technical specialists at Cypress gave me the attached schematic to communicate the CY8C24894 chip (data sheet attached) with a relay. The chip is on the PSoC in the schematic - which connects to a USB port. I’ve contacted them again asking for values for the four parts in the schematic. I’m wondering if someone might be able to answer the same question, and also take the time to explain to me what these parts are doing at these values.
Would the values of these parts likely have to be different for different chips?
Also, does anyone know of any example Java computer programs that can read analog pins on a CY8C24894 chip?
Do Java programs have to be different when communicating with different types of chips on peripherals, or can different types of chips read the same Java code?
  • DataSheet_CY8C24x94_C[1].pdf
The diode across the coil should be a switching type. The coil current and voltage decides which transistor to use. The resistor should pass base current >1/10 of coil current and this current should be < the chip output pin max current. If the same pin needs a valid logic signal for other circuitry, the pin voltage levels must be valid logic levels while supplying the 1/10 of coil current.
Is coil current the same as load current? What does base current mean? The pins are analog output pins at 8.8mA and 5V. Can each part in the circuit have many different rating possibilities – depending on the other parts? Or, is there pretty much just one range of ratings that the parts must have to be connected together in this circuit?
It's the load current for the transistor (8mA, see below). The load current for the micro is the base current (0.8mA, see below). The ultimate load has current that goes through the relay contacts.
Relay 45-191 from Hosfelt.com has a coil current of 12/1500Ω = .008 A and switches 0.5A so it has a current gain of 0.5/.008 = 700. The relay load current is 0.5A.
What does base current mean? The current that must go into the base in order to get collector current to pull in the relay. Relays and transistors are current operated.
So to get a collector current of 8 mA and
assuming the 5v does not drop very much when it sources 8mA and
assuming a 1v base to emitter drop,
you need a base current of 0.8 mA and,
so (5-1)v/.0008A = 5kΩ for the resistor shown in your diagram.
Yes, they are mostly interdependent, so start at the load current and determine the rest of the parts from there. However, generic relay driver circuits may cover 90% of the applications. The ULN series ICs interface from microchips to loads like this.
