simple question
sry, quite newbie at this
i'm trying to use a Double Throw Double Pole switch to emulate the keystoke of two letters in a keyborad, if i want to write "AL" i need to delay the letter "L" for 0.5 Sec.
Tks
AL
you didn't tell if you want the signal to remain at 5V after the delay.
The attached circuit is activated upon power on and delays both outputs. Adjust accurate timing using RV1.
Boncuk
Tks
AL
Would it be practical in your case to run from a script rather than doing it electronically? For example using the SendKey method?
Ron
Hi AlPita,
nothing easier than that!
Here is your "circuit".
Boncuk
