Perhaps I can try this in this section?
What is the absolutely simplest method of linking two momentary switches with RF?
Is there such a thing (fantasy probably) as a single chip? I'm imagining an eight pin IC with switch connection, power, rf in/out. Or even a matching pair. Ultra simple. A few dollars each?
I've seen this
Linx Technologies TXE-433-KH RF transmitter modules with built-in encoder
Linx Technologies RXD-433-KH2 Long-Range RF receiver modules with built-in decoder
But it's 25USD for the pair, and still more complicated than what I've described above. I have no training in programming or electronics. I know my way basically around board components, soldering irons, and general repair.
I need a range of about 100ft through obstructions. I found a wireless control for outdoor lights made by Intermatic at Menards yesterday for 9.95USD. Keyfob remote activates a waterproof pigtailed outlet good to 15amps. Without getting into a debate on predatory pricing and slave labor in China, why can't I just get a couple of chips from DigiKey to do this on my benchtop for much less than it (obviously) costs to manufacture this entire product?
I can hack this apart and shoehorn it into my project, but it makes me sad that I have to do such an end run around what ought to have a more elegant solution. I don't need joystick control or even multi link capability. Simply one switch activation. I can supply the op-amp and relay at the rcvr end.
Original post restored -such actions are NOT permitted here - moderator.
I've seen this
