Carpesimia
Ok, I think this is just a simple resistor question, but I could be wrong.
I'm installing a back-up camera in my truck. Normally, I'd just hook the camera to 12v ignition power, and be done with it. Except this camera has built-in lights to illuminate the area behind you.
That being the case, next plausable thing would be to hook it to the reverse light's power, so it comes on when I put the vehicle in reverse.
This is also well and good. Except I'm never happy with simple. I want the ability to see the rear display while I'm driving. My head unit supports it.
So, what I must do, it seems, is run off of a dual solution. I'll have the camera hooked to the reverse lights, so when I go into reverse it powers on. At the same time, I'm going to install a small toggle in my dashboard so I can manually power the camera on and off while Im driving.
BUT... I dont want to throw power to the reverse lights when I hit the switch, and I dont want to feed the other way in the event the switch is on while I go into reverse.
So, I imagine that I'm going to need some resistors on both sides. One between the camera and the reverse light, and another between the camera and the front switch.
Thats where my supposed knowledge stops. Is it, indeed, resistors I need? If so, how do I determine what size I need? What else do I need to know so I dont just hose my camera and/or my trucks electrical system.
Thanks!
Rich
P.S. - My apologies if I posted this in the wrong forum. After reading the descriptions, this one seemed most appropriate.
Thanks!
Rich
