I would like to replicate the action of a very low load automotive relay using solid state components. I understand simple electronic/circuit principles and what basic components do, and I can probably (probably) handle ohm's law, and I can solder, but that's about the extent of my abilities. I have no solid state design experience. I have no idea what core component to use to create this or if the isolation part of this is possible without jumping through hoops.
I am trying to integrate with some existing electronics in a car. What I need is to have the current coming from an existing momentary switch (providing 12v car power) close another circuit (momentarily also). But, the second circuit has to stay fully isolated from the first and from the car's electronics.
If I was using a mechanical relay, I would just have the first switch send 12v to a relay coil (other side of coil grounded). The NO contacts on the relay would close and complete the second circuit. I'd have full isolation between the two.
But, I'd much prefer to do this with a non-mechanical solution. The current draw through the second switch is close to nil. I will measure it, but it's actually just another trivial circuit that needs a momentary connection to do its job.
Is there a way to do this with solid state components an achieve the same level of isolation that a relay would provide between the functions?
