Dlipford370
Hello,
I have a board with a usb on it, and I need to extend the usb to a different location. Due to the placement, an adapter or anything that plugs into the usb will not work. Also, you cannot just un-solder the existing usb, and add wire, because this company ships their boards with some tough epoxy on them. My thought is to cut the usb away enough to easily gain access to these points seen here. If I just solder 5 wires to these points, and then coincide these wires to a female 5 pin micro usb socket - should that usb then function the same as the usb originally on the board or would is pose any issues? Also, is it safe to assume going from left to right on one board, the leads would hook up internally to the same places, within the other micro usb? Do you have any suggestions on a better way to do this?
Thank you.
Thank you.
