ozzieostrige
Hi all,
First of all let me explain I am almost totally self taught and have until now confined most of my activity in electronics to kit building.
I have the need for a simple moving dot voltmeter employing something like an LM3914 to monitor the charge state of an Optima deep cycle auxilliary battery installed in an RV to power a refrigerator and other accessories.
Optima has advised me that fully charged this battery will read 13.18 volts and when it has been discharged to 70% it will read 11.89 volts. Also I understand any attempt to discharge it further than 70% will result in a drastically shortened battery life.
Ideally I would like to use an amp hour meter but these are quite expensive so I will have to be happy with a volt meter.
The problem is all of the circuits I have seen monitor between approx 12.5 and 10.5 volts. eg one circuit I tracked down supposedly indicated 100% - 70% charge remaining. The problem is the 100% LED extinguished at a voltage of 12.47. At this voltage the optima is already approaching 40% discharged and if I were to continue using the battery until the "70%" LED lit I would have a very flat battery indeed.
I think the LM3914 may suit my application but I would have to adjust it to monitor a range of say 13.2 - 12 volts if this possible.
Can someone please tell me if this is possible and how to do it. I looked in the data sheet but couldn't find anything on how to accomplish this.
Any assistance you can give me with this would be greatly appreciated
Ozzie
Ozzie
