simulation on Ltspice of an half bridge inverter with a Igbt with diod in antiparallel
martamar3
I have to do e a transient simulation of an half bridge inverter with an igbt with a diod in anti-parallel, his name is ''IKW15T120'' by infineon. I don't know why the inductor's current is always negative, it's not alternate. some advice?
  • Draft1.asc
  • Infineon-PSpice_IGBT_1200V_TRENCHSTOP_2-SM-v3.0a-en.zip
The Schmitt trigger hysteresis appears to be causing an offset in the modulation duty-cycle.
Try increasing the sinewave to 90V and the pulse input to +/- 100V A1, to minimize the effects of the hysteresis.
Or use a comparator without hysteresis for A1.
