This perhaps has a lot to do with programing, but just the same I believe it to be relevant to this forums.
I'm currently working on a project that involves digital sound processing. Currently, what I want to do is be able to simulate a simple to relatively simple circuit (guitar effects pedal) in real time. Digital audio would be fed into the simulation and the simulation would treat it as if it was an analog signal running through the circuit and then output digital audio again.
The following is an example of the type of pedal circuit I might need to emulate. To my knowledge, nobody else has or is doing this for any reason. At least Google hasn't turned up anything. My real question is whether or not it woul be feasible to simulate such a circuit with the required accuracy and at the required rate to produce a real time audio filter/effect. We're talking about 16 to 24-bits audio precision at sampling rates of 44.1KHz to 96KHz.
Thanks for you help in advance.
