Sine wave output from crystal oscillator
Notary Sojac
I built a dual-inverter crystal oscillator circuit, but the output is a bit less than sinusoidal. Adjusting the capacitor between the inverters cuts down the distortion a bit, but it's still obviously not a sine wave. What's the best way to go about this? A bandpass filter? I tried a ladder filter and that only seemed to make it worse, and I'm not familiar with any other filter designs that give the astronomical Q values required (oscillator is around 13Mhz).
Any suggestions?
You could use a narrow bandpass filter centered at the crystal frequency.
Alternately you could use an oscillator configuration that generates a waveform closer to a sinewave such as a Colpitts or Pierce.
