Based on the way the question was worded, I doubt the OP can answer most of those questions... Maybe the what forWelcome to ETO!
What are the voltage, current and output impedance requirements of the producer? What will it be used for?
ThxThis application note, AN-263 Sine Wave Generation Techniques, should give you some good ideas.
YW.
If those subjects include humans, be aware of the dangers. From what I've read, frequencies around 7Hz can trigger epileptic seizures in susceptible people.It will be used in a series of expironments to test the effects of 8 to 10 Hz on various subjects.
They did yes, but they didnt do it right, vibrate the bowl at 10HzDidn't the Mythbusters do something with 10Hz Brown note frequency. As I recall Myth Busted![]()
They where 2x18" subwoofers, which would typically handle 60Hz and below. They blocked the reflex ports to effectively make them sealed enclosures. Not optimum output at 10Hz, but significant.The PA speakers used by the Mythbusters were for voices and could not produce low frequencies
