Stephane38
I have designed some piezo harvested circuits designed in LTspice as attached.
The first one is a simple case, the piezo is modelised by the current source I1 and the C1 capacitor. Then there is an diode bridge and finally a storage capacitor C2.
In the second design, I added a sw which has to closed when the I1 current reach 0A (SSDC).
When i want to run my design with an 0.025A, it poped up with "Singular Matrix: check node entre- Iteration no4"
BUT when I change to a 0.024A, there is no pb and I have the results I want.
Then the last circuit arrives, it's the same with an inductor (SSDCI).
It poped up with "Singular Matrix: check node n001 Iteration no4"
So there is a pb with C1 node. When I add a node to n001, the problem is solved but that isn't the results I want to use the diode bridge rectifier (like the first circuit but with an switch).
If someone can help me please ?![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
