Silicon chips are normally 125C junction. If it is thermally protecting itself it is shutting down and not running.I provide more details ;
Tjc=22C/W
Tja=80C/W
If I provide a sink with coeff of 11C/W . How much the Junction will be lowered at 85C ambient . I can reduce the power to about 0.7W no less than that . What I want to know is how much temperature releif the sik will provide . Thanks for Actel link .
I know Dan the chip will work at 165C but it wont fry , it has built in compensation to reduce the supply and certain other things , but I dont want to operate at that temp . You say if its not mentioned to sink the chip then one shouldnt do that , BUT half of the industry runs this way and is successfull! . I dont have an option(due to power constraint) but people provide peltier sinks to achieve one.
Normally all you do is add the thermal resistances, multiply by the wattage, and add to the ambient. (22+11+1(guessing, it depends on how good the interface from the pad to the sink is, and I am assuming you have a sink pad since it gives a junction to case))*1W+85C=119C dangerously close to 125C but doable.
For a peltier you are looking at your power plus the peltier power going into the heat sink. you are probably talking about 4W going into the heat sink for 44+85=129C at the peltier. if you get one that will get you 40C down you are at 90C. either way you need a better heat sink or a big peltier.
Dan
if the package is not designed to use a heat sink, it borders on useless to put one on.
Dan
