Hello all.
I would like to be able to sample six channels of audio and send the audio to a computer via USB.
The audio does not have to be of pristine quality, but "stops and starts" would be a problem. The data should be regularly sampled.
I'm not experienced with PICs. From searching around it seems that most PICs would have multiplexed A/D, with only one A/D converter, of which the channel has to be selected before sampling. So that means that, say, 8000 times a second I have to change the A/D channel and sample a value, plus I have to send the data down the USB line.
From what I've read, I have a serious problem in terms of speed, and would guess that standard PIC chips would not manage this. I'd also have trouble, I would guess, with the total data throughput with USB.
I'm aware that I will have to have some analogue filtering ahead of sampling to prevent aliasing.l
Can anyone advise? Is such an application feasible with PICs?
If not, to what degree would I have to reduce the number of inputs before it's likely to work?
