small switches
Matt79jd
I have been working on modding personal vaporizers for a month or so and i need some technical help. The Atomizer that needs power is rated at ≈ 3.2-3.4Ω and I'm supplying it with 3.7 volts. I only need the power for ≈ 4-6 seconds. But will be pressing this switch a lot. The smaller the better. I have been using a 5V 2A LDO voltage regulator with a control pin so I'm able to use any switch but the regulator is to big for the application. I make other mods that are supplying it with 5v for more wattage. Anyways I have been looking for small switches for way to long and still i am searching. I was also wondering if creating or buying some kind of component like the regulator would be possible. Thank you.
Some pictures of my first mod.
I'm using a 2xAA battery box.
My goal is to get it smaller.
