Misterbenn
Active Member
Hi guys
i'm trying to build a smart battery monitor / charger
So far i've got my smart battery, but i'm still trying to work out the layout of the SMBus conector. Its a HiModel 11.1v 1300mAh battery pack, with power out and then a 4 pin connector.
From what i've found on SMBus it should have a clock, data and analouge 'safety' signal. the safety signal should just be a resistance value i belive.
Out of the four wires (black, yellow, blue, red) i've been able to work out that black and red have a PD equal to that of the battery - which suggests power terminals. However if they are just power terminals then i've only got 2 pins left, not the three required by SMBus specs.
Also looking at the yellow and blue in regards to black they have seemingly random but constant voltages - i expected them to be logic low as the smart device should be off.
Has anyone out there had experience working with Smart Battries?
