SMD Resistor markings
Scarr
Hi all,
I have two resistors, can anyone tell what tolerances they are, they have the markings
102
10B (that is a B not eight)
Or can you not determine it?
Steve
If the first is a resistor it should be 1K as in One-Zero and two zeros. I am not sure about the second one.
Ron
Pictures
I have attached some pictures to help with my question.
Steve
Three figures on an SMT resistor indicate the value -- first sig digit, second sig digit, power of 10 multiplier -- of a 5% device.
Four figures on an SMT resistor indicate the value -- first sig digit, second sig digit, third sig digit, power of 10 multiplier -- of a 1% device.
The letter "R" is a decimal point indicator for low values, e.g., 1R8 for 1.8 ohms, 49R9 for 49.9 ohms (1%).
However, I'm no SMT guru, so resistors with better than 1% tolerance? Don't know.
10B? Dunno, either. What does your ohmmeter say about this part? That's the first step in analyzing a part with an unknown value.
and its NOT 10B its 01B not that it helps I havent seen a resistor marked as such
definately needs to be measured to find out :)
Dave
Oops. Went by the text in the OP and didn't check the pics. Measure the thing with an ohmmeter and see if there's low resistance or an open. If open, I'd suspect a cap, value of 0.01µF. However, in most cases it would be marked as "104".
01S
The 01B is 1kΩ
So is the one labelled 102
They use different marking schemes.
The tolerance isn't marked. You have to guess. However, 1% ones aren't expensive.
Outstanding Diver !!
havent seen that list before, has now been saved to component data folder
cheers
Dave
