SMT PIC Programmer - Log!
bsodmike
Hey there guys...
I thought that some of you here may enjoy the following images.
Initial drilling for the PCB mount:
Close up of power switch and pilot hole for the power connector (3.5mm jack)
full show showing installed switch:
Connected two blue led to help light up the case. I've been told to actually attach them to the 'programming' led line but I will not be doing this as there are onboard power/program SMD leds.
Next update: When the special din connectors/mic jack arrive and I finish soldering the PCB.
nice photo
good work
And here are some images depicting the progress on the programmer:
Here I have drilled 2x 12mm holes for two DIN connectors
This little contraption is what connects the ICSP header to one DIN conenctor - I'm also grabbing 5v off this for the two leds!
Another shot of the ICSP receptacle:
Here is an 'in the dark' shot of the first SMT prototype. Some problems cropped up which have been sorted:
The final PCB soldered:
...and a test fit!
More updates Wednesday!
e_azzaz: Thanks :D
(Y)
well
you have made a nice seeing pcb board..??
where is you company established..???
maybe i have some work for ya..
TKS
I take worldwide orders so it isn't a problem. If you are in a hurry PCBs can be shipped via FedEx (for about USD35-40 rough estimate) or regular Air Mail (cheap!). Just drop me an email and I'll take care of things 8)
pcb's....
i was wondering he..
the pcb out there are there ones that have one side totally covered whit a thin cupper layout or any other material that good conducts..??
i was wondering if you also could build a pcb machine when only seperating the head line...
in stead of drawing the head line..
TKS
