Hello all,
I just finished building the phuncgnosis effects pedal (http://folkurban.com/Site/Phuncgnosis-719.html) on a breadboard.
For some reason, not just with this pedal but with every op-amp circuit I have built on a breadboard, I am still getting sound when the op amp is turned off and the 9V supply is physically removed from the circuit. I read Analog Device's article on "off amps" and I was thinking about adding a series resistor like they suggested to see if that helps. I want to put it in series with the .01uF cap and the non-inverting terminal if U1A. Would this cause me problems? Is there another solution for the issue of getting sound without power?
