Hi Folks, It's been awhile since I did much circuit work so my apologies if I sound ignorant.
The concept is below, and any help designing it would be beyond appreciated![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This project is in essence an ohm meter with some odd specifications.
Preferably ran off of 5VDC via USB charger in a cigarette lighter.
Wired
low power consumption
Wired
- In need of a basic circuit is in essence an ohm meter. Preferably an array of ohm values, where if the probes are inserted into soil that has 80% moisture, a blue LED turns on that notifies the driver the soil is too wet, if the probes are in contact with soil that is 55% moisture, a green LED lights up to let the driver know the soil is in the optimum moisture range, and if the probes come in contact with soil that is say below 40%, a red LED turns on letting the driver know the soil is too dry.
- I need a circuit that "blinks" (turns on and then off_ the voltage through Electrode 1 - through the soil with moisture content (what ever %) into Electrode 2. I have the electrodes which are a specially designed galvanized probe used in agriculture. I need 5 volts to pulsate through the probes using a potentiometer (preferably not a 555 Timer if possible). The rate of blinking will be adjusted depending on the speed of the tractor. The reason for needing to "blink" the voltage is to reduce the amount of electrolysis that is common when doing moisture reading with DC voltages
