Mohammed Kaddoura
Hello everyone, as i am new to this forum, i would like start with you with my graduation project.
Its supposed to be a Solar optimizer and a square wave inverter with a solar sun tracking system
but i didn't have enough time to finish the solar tracking system so i will continue it later.
as you can see I'm using a PWM circuit and also a current meter which is connected to the optimizer and the optimizer is connected to a microcontroller which will control the optimizer system.
I have added another Micro controller for an LCD to show the voltage and the current coming from the Solar Panel
I have almost finished programming it but didn't test it yet
Aright so,,, Hope you like it.. If you have any questions you can ask![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
**broken link removed** **broken link removed** **broken link removed**
Red led = Battery is Charging
Green = battery finished charging
Yellow = Inverter is on and 220v is on the output, i am using variable resistance to control the frequency and voltage.
in my country frequency is 50 hz and 220v
The output voltage
The output voltage
